Failed Reading Input File
Hello!
I recently installed Keyshot 2023 and am trying to use the render queue but I am getting the error “Failed Reading Input File” and then a path to my Scene folder.
I have tried on both Windows and Mac and am receiving the same error. However, I am able to run one render at a time. I am running the educational version of Keyshot (not sure if this matters). I have tried changing the permissions on the folders but this doesn’t seem to have solved the issue. Any help would be appreciated!
I’ve never seen that error but could it be the directory name is really long or uses special characters (like some countries use?). That shouldn’t be a problem but if it does you might try to give the directory a really simple name.
I guess that might be some problem with restriction, so that KeyShot isn’t allowed to save the q.xml in the scene folder
Could be possible, than I would try to start KeyShot with right click and ‘Run as Administrator’. But it’s weird if the problem is the same on Mac/Windows.
